- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi I have just purchased a KLDW605B TV and I have a Sony DAV S800 home DAV compact s AV sound system, could anybody please tell me if I can use this with my TV and also how to connect it up. Thank you
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Connect a single composite cable (Yellow RCA connector) from the TV (AV2) (see location of ports : HERE) to the DVD player. I think you will need to change to AV2 to watch a DVD. If you want it on AV1, you will need an adaptor (couple of quid) for a SCART to Composite.
You can either use a red/white composite cable for the audio, however I would personally use an Optical cable from the TV to the DVD player. You can then output the sound from the TV to the DVD player if you set the TV's speakers to "Audio System" and then set the correct source on the DVD player.
Alternatively, considering that you have a new tv - have you considered a new all-in-one bluray system to go with it instead?
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for your reply ,I forgot to mentioned that I was going through a Sky Box as well ,so would the setup still be the same. Sorry and Thank you::smileyrolleyes:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
The missing detail but not to worry - setup should be the same I think. Just connect Sky box to the TV.
