I have a sound bar a few months now.
I noticed if the cable box volume is not on 100% the sound bar willl turn off after 10 minutes.
I have defaulted and connected again.
The cabke box is connected to the sony tv which is connected via optical link to the sound bar.
Hi there
In regards to this problem and your other problem HERE, my advice is to replace the SCART cable with another one of sufficient quality and see if that works.
In the long run though, you may want to contact your cable provider and get them to replace your cable box that has a HDMI connection instead of SCART. SCART is all but dead. Besides SCART does not support HD resolution.
