I have a Sony X85 TV. In my Apps I can open sites and Add to my Apps where they can also open. The only thing I can't do is open the radio stations eg. Capital .Smooth Radio etc. in Apps. They show they want to connect. I can add them to My Apps and they will still not open. Is it because these radio stations have been discontinued or what other reason can their be.
I spoke to a Sony Agent and he talked me through doing a factory reset. Doing this reset has solved my problem and now all my apps on my TV open.
Hi there
I no longer have a 2014 TV to test this out, however they work on my 2013 (KDL-42W807A) TV. I would suggest doing a "Refresh Internet Content" via the network menu and try again to be honest.
Hi there
I know you said that you are connected to the network. Am I assuming that you've connected your TV to your network via wireless? If so, can you please connect an ethernet cable to the TV and change the TVs network settings to LAN cable. Then give this a test out.
Im just trying to determine if its an intermittent network issue.
If you are still having problems even when connected via a LAN cable, can you ensure that you have the latest firmware installed on the TV?
Glad you have got it working. Amazing how often a factory reset seems to work
Thanks for posting an update.
