goodevening,i have a SONY WEGA KV-32FQ86E .it isn't turning on ,but the led in the front is flashing eleven (11) times then stops for a second and begins again flashing and thats keep going.does anyone know what kind of problem is this or what part should I replace in order to fix it myself? thanks a lot
Hi there
Doing a google search, I cannot find what 11 blinks mean for your model tv. I have found a service manual though (link below). However, even if you find out want the blinks mean, I think the hardest part is actually getting hold of the exact parts. In the end, I think it would be more economical to replace the TV completely. LED TV's have come down in price over the last few years, and some of the features that are integrated, are fantastic.
http://www.scribd.com/doc/100875692/SONY-KV-32FQ86E-SERVICE-MANUAL
Anyway, good luck if you persue this.
