- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
March 2013
March 2013
How do I convert an Indesign document to either a DCF2.00 or Exif2.21 file? I have tried normal .jpgs but it does not work through a USB card. We have created the appropriate directories but still does not work.
We need to play a procession of jpgs (on screen presentation) in a reception area.
Can anybody help me?
Kind regards
Carole
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
March 2013
March 2013
If you open the jpgs in Microsoft Paint and then save them again, then drop them into the directory on the USB stick, the TV should recognise them. You can set the directory to loop also, viw pressing options on the remote when they are playing.
Thanks
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
March 2013
