KDL55W805 - When Subtitles/text appears on the screen and motion happening in the background it distorts the subtitles/text anyone else had this?? its only slightly but it shouldn't happen should it??
What could cause this is it a fault?? it happens on satellite TV and through my video player.
Hi there
First thing to do, is
Ive not heard or seen any reports of this issue to be honest, so probably isolated to your TV / equipment.
I comfirm that too with W905 model. But I discovered that when I read you post, not before I suppose the problem is caused by video processing alghorithms. The subtitles should be added (if possible) after processing, not before.
