I've just set up my TV and put it on the stand provided...
There is an ever so slight but noticible slant on the TV from right to left, about 5mm from each end.
is there a possiblity the stand is broken or fixable in any way?
(who to a contact to fix if there is no quick fix.)
Hello lyndtok,
If you need to contact Sony about this issue directly, you can contact them on 0844 8466 555. Or you can email them by filling in the form here: http://bit.ly/1hwuq7r
Kind Regards
Clarissa
it is possible that you have not seated the tv to the stand properly, check also you have followed instructions and try again.
