Hello
I have been trying to access the Sony Entertainment Network "All Applications" list, which only brings up a few applications unless I leave it loading on the page for 5 minutes where it finally comes up with the entire selection.
Once this has happened, if I try and go on an application such as Netflix, I receive the message "The application is temporarily unavailable. Please try again later". The same happens with other apps such as Sky News etc.
My internet connection is fine and have tried both wired and wireless. I have reset the internet aswell as doing a factory reset and unplugging the television from the wall for 10 minutes.
Could someone please advise me on what I can do to get this working.
Many Thanks
Update my firmware last night and the all the apps are now showing but only a few apps where working last night like Lovefilm. BBC iplayer didnt work. Today the Lovefilm, BBC iplayer and most of the one I use apart from Mazu the music channel which still comes up with service not available.
Apps were working earlier but have just tried at 6:30pm and they are no longer loading.EDIT Maybe a blip or something my end as i reset everything and seems to be running again now.
Guys,
we heard you and thanks to your info and anlysis we are making progress. Please check this thread for updates:
Thanks,
Nico
Good to see a critical mass of forum members helping to get this problem sorted out...even if it took a week or so to get the ball rolling! Hope I can now watch Masterchef, Bakeoff and Modern Family without being on tenterhooks about the service collapsing/not working.
I think it works like this for many companies :
During the initial stages of the week, only a couple of people reported the problem, with it seemingly resolved itself. Hence no flags were raised as such. But as the problem kept re-occuring and many more people reporting in the same problem, that priorty then gets raised, hence more people involved in finding a solution.
Should start a sweepstake on who can guess the exact problem
