How do I disable the USB device so it is safe to remove, I have looked through the menus and cannot find a way to do this. Otherwise everytime I pull out a USB drive it could damage the filesystem as the TV keeps it active.
Bump!
I've just asked the same question of Sony's support and the answer is that safe removal of a USB device is not supported!!!!!!!!!!!!!!! Their advice is TO SWITCH OFF THE TV. INCREDIBLE.
David
