Hi!
I'm in the middle of buying a Sony Soundbar (SU-B461S) for a Sony KDL-EX710, but one thing is itching in my forehead. When looking at the SU-B461S product page, it says that the soundbar is compatible with the following TVs:
KDL-46HX920
KDL-46HX820
KDL-46HX825
KDL-46NX721
KDL-46NX723
KDL-46NX725
From just looking at the pictures of a couple of those TVs, they look very similar to the KDL-EX710. So, does the soundbar work with my TV? Does anybody have a good answer?
Thanks in advance,
Jacob
Nope, those stand-soundbar are dedicated to the Monolithic design HX/NH series. You can't use it with other series since it uses a special connector
Plus that's not a sound bar but a stand with speakers....
