Hello!
I made one favorit channel list, how I can change channels order inside this list? It was possible in my previous Panasonic tv!
Markku
Hi there
If you highlight the channel you want to move, and press the [Options] button on the remote control, is one of the options that pops up -"Move"
Thank You very much! But how can i highlight the channel i want to move?
Merry Christmas!
Markku
Hi!
I called today Sony Support Center. They told, that in this model it is impossible to sort channels inside favorit channels!
I think that it is quite a big problem! In all other TV:s we have now (Panasonic plasma 50", Panasonic LCD 37", Samsung 21") such thing is very easy to do!
Markku
Thank you for the update.
I wasnt sure to be honest, but I would have thought that you could do it, as it would be a basic function to implement as you rightly pointed out. A bit of an oversight I guess.
