i has simple problem, when i try watch .mkv file via USB, TV show notice that content is not supported but video is correctly played. How i can fix this bug?
TV has latest drivers: PKG4.201EUA
Fyi: I'm from Slovakia and I try ask this question here.
Please help me, regards,
XXXX XXXX.
*Please note, your post has been edited, as for your safety reasons, posting your full name and surname on the forum is not permitted.
Hi there
Unfortunately there is no fix at the moment for this. It seems that you are not the only one who has this problem, as a couple of other threads are reporting this too:
http://community.sony.co.uk/t5/Televisions/File-Format-KDL-47W807A/m-p/1384620
Hi there
thanks for response. I'll waiting for hotfix.
Regards,
striky.
Thats ok.
I can confirm that this issue has been raised with Sony.
