I have a Sony KDL-32EX723. Its on my home network using DHCP (though I experience the same issue when using a static IP). None of the Internet content is loading. Each time I try and watch iPlayer I see the error "Configuration failed while connecting. The service cannot be accessed at this time; reference code <1107>".
Firmware is PKG4.017EUA-0104. Testing the network setup shows Cable OK and Local and Internet OK.
The TV has negotiate a 100M FD connection to my Gigabit switch.
Any ideas?
Jiz Zah
I have the same problem, have you been able to solve it?
