Tv switches itself off seconds after being switched on ….any connection between this and installing software update ? Ie update is due to be installed
Not a lot of information there.
What model of Sony TV is it.
What update is pending.
If a TV is switching itself off after you switch it on that would suggest there is a
fault with the TV.
Is your TV still under warranty, if so and you suspect a fault contact whoever sold you the TV.
