x
Sony Bravia SmartTV EX653 Channel Sorting; sdb.xml
profile.country.en_GB.title
LordD.
Visitor
The Channel Sorting interface used by the Braiva range is,... pretty poor.
Does anyone know if it's possible to export / sort / import the channel list by editing the sdb.xml file? The file certainly lists the channels but it's not obvious how their order may be changed.
Exporting the channel configuration, resetting the TV and then importing sdb.xml certainly preserves the channel order,... so I'm guessing the order is contained within sdb.xml,...
Help?
1 REPLY 1
profile.country.pl_PL.title
user_from_PL
Visitor
User 'Stubbs.' on Polish forum recommends http://www.sony.de/support/de/product/KDL-46HX755/downloads/Sony_Editor to work with sdb.xml
The program supports German, English and other languages. Once you have installed it, you will find manuals in the same folder as the program (exe) is kept.
Good luck.
