i`ve just bough a soundbar for my Sony Bravia tv it came with a optical cable but it wont fit into the port on the tv, the only port i can find is for a jackplug,the port i want is bigger and pushes in through a little door, it also came with a coaxial cable and theres nowhere to attach that or am i missing something, ive looked all over the back and sides of the tv but cant find nothing, help please
Hi, the soundbar is a Bose Solo5 sound system, thanks in advance
Hi there,
Welcome to the community.
Can you let us know the make and model number of your sound bar please?
There's also some advice for using audio and video equipment in the manual here.
Best wishes,
Ed
