Since a software update about two weeks ago, I am now unable to access YouTube, Netflix and other apps. The only way to get round this is by switching my TV off at the wall, waiting a couple of minutes, plugging it back in and I can then access all internet-based stuff. I have to do this on a daily basis now which I should not have to do. On checking network settings before the reset it says:
Connection Results
Wireless Device on TV - Not Accessible
Local Access - Failed
Internet Access - Failed
All My other devices are connected to the internet without a problem.
I have also done a factory reset which made no difference.
I notice that there are several other posts who are having the exact same problem.
I went on live chat but they failed to give me a solution only a firmware update.
Anybody got any ideas? Is it the TV?
I have same problem.
The only way to connect to You Tube etc is to un plug the DC plug to the TV..same as removing mains plug.
Then it connects.
Only since last firmware update.
I swear this is the last Sony product I will buy.
Nearly every firmware update gives problems.
Keith
Redruth Cornwall
It's the firmware update that has broken it.
In the hope that there is a later firmware that will fix this serious problem.
Surely you should not need to do a power off reset to use the the Smart features of a Smart Tv .
I will be switching firmware updates off.
It's a pity that we can't go back to the previous version that did work !
Keith
I have the same issue and it's very frustrating- this is the same issue as I experienced on my old (Samsung) TV that eventually completely lost the ability to connect, was hoping Sony would be more reliable...
I originally found switching it off and on at the mains for 30 seconds fixed the issue, but the same as the above I now have to do this every single time I turn on the TV. I barely watch anything on the TV except streaming so it's very annoying!
I raised this with Customer Support.
I had a very long email with a whole list of questions to answer.
I have not replied yet as I may have found a fix.
This only relates to my problem that You Tube would not connect to the internet via wireless.
I can't try via Ethernet as the router is too far away.
I have tried & will need to test over night.
Once you do get You Tube to work.
I went into the menu, an Item "Reload App".
A warning is given that it will deleted saved searches etc
I did the Reload & am hoping this is going to help.
Will know tomorrow after being on standby over night.
We tended to Exit You Tube before putting the Tv on standby.
The next day, switch on, Freeview fine, You Tube same old problem.
Wanted you to go into network setup but never found could find the network.
As you say power off reset fixed it.
I will let you know the outcome.
Keith
After being off overnight back to square one.
I was checking only YouTube but today checked other apps & all are affected, asks you to set up network.
So complete factory reset, set up network & free view again.
Will test over night after being on standby.
What Sony don't seem to accept is that as customers, we haven't made the Tv faulty.
Sony has, since the last upgrade but we are doing their faultfinding.
From what I can see the software package is from a 3rd party.
That's NOT my problem !!
I have had an e-mail tonight off Sony support asking for my device ID.
They claim that the issue has been sent to higher technical support.
It is still happening on a daily basis and is very frustrating.
Let’s see what they say next!
Me too
I had under, did all they suggested filled it in & been sent off.Lets hope this gets sorted soon. Keith
Thank you for contacting Sony support.
With reference to your enquiry regarding your Sony KDL-43WF663, in attempt to resolve the issue, kindly find the troubleshooting steps below:
1-Disconnect any external devices connected to the TV.
2-Unplug the main power cord of the TV, and plug it back after 2 minutes.
3-Refresh internet content by following the steps below: (Press Home - Settings - System settings - Network - Refresh internet content)
4-If you are connected to the router wirelessly, try wired connection if you have an Ethernet cable.
5-Connect your TV to hot-spot following the below: (Home - help - settings - system settings - network - network setup - easy - wifi - connect by scan list - then choose the name of your smart-phone and enter the password).
6-Perform factory reset following the below: Home - settings - customer support - factory reset
If the above didn’t help to rectify the issue, please answer the below questions for further investigation in your case:
1-What is the device ID? (Press Home - Settings - Customer support - Product information)
2- What is the current firmware installed on the device. Please write the exact version. (Press Home - Settings - Customer support - on the top of the screen you will find it)
3- What is the MAC Address? Home - settings - network - network set-up- view network status)
4- What is your Post Code?
5- What is the internal device IP Address? (You may refer back to the internet service provider for further assistance)
6- What is the public IP address by visiting www.whatismyip.com?NA
7- What is the internet Service Provider Name?
8- What is the actual internet speed using SpeedTest.net?
9- What is the network environment: i.e. FTTH, Broadband?
10- Are you using VPN / Proxy / Anonymizer / TOR service to access the internet?
11- What is the brand and model of the router?
12- What is the results of connecting your TV with your personal hotspot?
13- How is your TV connected to the internet? Wired or Wireless?
14- When did the issue start?
15- please provide us a picture showing the apps page
Should you have any further questions, please feel free to reply to this e-mail.
Thank you for your enquiry.
I had similar problems, my Wi-fi kept dropping out. I came across this :
https://www.smartaerials.co.uk/blog/sony-smart-tv-keeps-loosing-internet-connection
Worth a try ??
I would go with Ethernet if I could but router is in kitchen on the master socket.
Have now had this >> please note that your case has been raised for further investigation , please allow 2 business days for the outcome.
We live in hopes !
Keith
