Shortly after turning the power on, the TV will make a loud-ish bang and switches itself to standby. The red power light flashes twice every 2 seconds. Unplugging from the power for a while and then plugging back in produces the same result. Any thoughts as to why this might be and what I can do about it would be appreciated.
Hi there
Unfortunately it appears that the TV has a hardware fault. You will need to contact an authorised Sony Repair Centre.
2 Blinks
Hi there
2 Blinks
Many thanks for the quick reply.
No probs
