I've just moved into a property where the above mentioned TV had been left behind.
They previously had it mounted to the chimney breast but i'd prefer it on a TV unit. Is there anywhere I can buy a tv stand to bolt to the back of the TV as they haven't left it behind. I've searched Ebay and Google but haven't had much luck.
Thanks, Tim.
@stim1986 wrote:I've just moved into a property where the above mentioned TV had been left behind.
Thanks, Tim.
Hi @stim1986. If you cannot find an original stand at a reasonable price then perhaps you could use a VESA stand which will fit any TV. Search VESA stand on a well known on-line retailer.
Thankyou! Exactly what i was after!
