- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony Bravia KDL-32E4000
I am an owner of KDL-32E4000 and i am experiencing problems with the DVB-T Signal. When i switch to Digital the whole TV starts to crash and slow down ... and suddenly it turns off. Does it have to deal with the firmware or something? Any solution?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
probably your signal reception is bad. try moving antenna around, see if you can get a better reception. and check the antenna cable is hooked firmly enough.
as I hear the digital switchover just started in Macedonia and the TV channels might have their troubles with the signal.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hmmm... Dont know what could it be ... When i bought the TV 3 years ago digital tv was working fine. Maybe the problem comes from the signals as you say : ) I hope it will be ok after the official digital switchover on 31th May ... Thanks however
