- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony Bravia KD55xe7013
Hi every time I try to open an app from the application screen I get an acquiring internet content message. When I check the connection is fine. I turn tv off at wall and then retry it goes through same procedure again but will then work but I’ll have to sign into all the apps again. So every time I turn the tv on I have to go through the same rigmarole. I’ve even moved the tv to a different room thinking it maybe the WiFi but same thing happens. Help please
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Chloe.garrie and welcome to the Community
I can't find that model number, is it the KD55xe7073 you have?
If so the first thing to try is a soft reset and failing that then a factory reset.
Details can be found Here
If that fails then its best phoning Support on +44 (0) 2073652810
and at least you can say you have tried the resets.
Hope this helps.
