Hi
please help me
the TV is restarted by pressing the [HOME] button and then pressing [RETURN] on the remote control
i have firmware version 8.673
now this version is unavailable on sony page
and i read on sony support firmvare version 8.674 fix this problem,
I can not install this update via wifi or usb
tv does not show me a new update for my choice
I tested everything according to the instructions on sony.com . many times
i try factory reset and after try find firmvare but nothing.
thx
Hi Robo222,
Well, in this case, I'd recommend getting in touch with Sony support to check what are your options to have the TV inspected by an engineer. You'll find their contact information on this link.
Regards,
Batee5
