Help please?
Was watching the TV no problem - then the sound just cut out.
Now, the TV is stuck on one channel only and, whilst the LED flashes when I press some buttons on the remote, nothing happens.
Cant even turn the damn thing off! Have un-plugged the power from the socket but even when it is left for half an hour and then plugged back in, the same channel appears, with no sound and the remote not doing anything but flashing the LED.
At a complete loss as to what has happened and what to do.
Any ideas - anyone????
Carl
Hi @carlmt
You have posted your question in the Android TV community. By the looks of it, it is a Linux TV so you may get a quicker response in the https://community.sony.co.uk/t5/other-tvs/bd-p/tv_en_1 community.
If you don’t get any help I would try Sony UK Support
Hi - Thanks for putting me right.......you can see that I am a complete technophobe!
Here's hoping someone can help out.
