Based on all the forum messages I've seen regarding this - it's more a SONY than a specific Tv model issue.
According to the manual, the following is supposed to fix this;
On the remote control, press RETURN then
press HOME and select [Settings] then [System
Settings] then [Set-up] then [Auto Start-up]. Be sure
to select [Home] in [Location].
However when I select the Auto Start-up option I'm presented with the Privacy Notice instead.
Is there any chance of a software/firmware fix in the pipeline any time soon???
Who'd have thought something as simple as this would remain unresolved for so long....
Hi there,
Can you let me know the full model number of your TV?
Best wishes,
Sean Mc
Full model Number: KDL-32WE613
I have the same issue. I have tried the following suggestion, but when I select 'Channel Setup' there is no mention of the 'info banner':
