Hi there
Unfortunately there is no solution in regards to outputting sound via online sources over SCART. I am unsure if this is a limitation of SCART itself or how Sony have impletemented this via the TV's software.
Upon saying that, fortunately for you, your DVD system has a HDMI out and an Optical port. You can resolve your problem by replacing the SCART with a HDMI cable AND an optical audio cable. Then you just tell the TV to output audio optically.
Hope that helps.
Hi there
Hope that helps.
