Hello,
I bought a new Sony Bravia KDL-40R455B and I'm very disapointed with slow loading of Guide menu and other features (Sometimes it takes about 15 seconds to load Guide menu). I had old Sony TV and everything worked well -> my antenna works well.
I tried reset TV to factory settings and updated firmware (v8.117). Nothing helped.
I'm pretty sure, it is just firmware bug by Sony.
Is there any way to fix this? Can I contact Sony development team or somehow repair this problem?
Thank you
Hi Jerry,
Sometimes I have the same experience on my W7. I found out that this seems to be related to some data that are loaded in the background. After these updates are done guide is quite quick.
Pumpkin Duke
