x
Skip AV inputs on HX803?
profile.country.en_GB.title
zorba_g
Visitor
I've just spent a very happy first week setting up and tweaking my HX803 (I had to do the firmware update manually to make iPlayer work, but that went fine). However, I can't figure out how to remove or skip the AV inputs in the input select menu. All the devices are connected by HDMI but the AV inputs are still on the list. Also it would be good to skip the TV input as I don't use that either.
Thanks!
Mario
Tags (2)
0 REPLIES 0
