- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Setting up avr
I have recently bought a strdn 1030 av amp to work with my Sony blue ray, Sony DVD/hardisk. Sky had box and a new sonos connect. I have managed to set the system up but have two issues . First I can't turn the tv off without the amp going off when listening to just music - how can I do this. Secondly the sonos is connected via the optical cable and works but the volume has to be considerably higher than any other volume to work.
Currently I have. Hdmi from blue ray to hdmi blue ray input on amp
Hdmi from amp to Sony tv
Hdmi from sky to tv ( so I don't have to always use amp) ...but only 1 hdmi on sky box
Hd DVD is older with no hdmi ..but has optical and coaxial I am using the coxaxical lead to amp
Tv to amp via optical (tv input)
Sonos is connected via optical to assignable optical input on amp
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
There may be a setting on your tv called Auto Devices Off in the HDMI Settings
According the the onscreen manual on my TV: Audto Devices off - Turns off the connected equipment when you turn off the TV.
Hope that helps
