Any help gratefully received- KD43XG70 new out of the box, followed all set-up instructions, get as far as finding digital & analogue channels, get a ‘ No signal, check your antenna connection’ message. Absolutely nothing wrong with the signal ( Virgin cable) as it was working perfectly well on previous TV when unplugged 10 mins earlier. I’ve done all usuL checks I.e. shut everything down,leave 5 mins etc. Checked all antenna connections, all appears correct.(Sensible) suggestions please!
Tom
Plug the Virgin box into one of the HDMI ports then select it via the input button on the remote (top left button with the arrow) and you should see your usual Virgin TV setup.
