Hello all,
I've recently been given a KDL-40EX724 which has the stand but is missing the screws to attach the TV to the stand.
I've found the following screws:
http://www.4sony.co.uk/stand-screw-set/product.pl?pid=2909767&query=SONFX0003991
but am unsure whether these only attach the TV to the stand. The stand (which comes in three parts: head, neck and stand) also appears to require further screws to make it good. Does anyone know whether the above link to the screws does it all, or whether I need a further set?
Thanks in advance,
Tom
Hi there
According to page 8 and 9 of the manual:
http://pdf.crse.com/manuals/4269995161.pdf
According to the link you provided:
Considering that you only need 3 screws to attach the stand to the TV, there is another 3 screws in the set provided by 4sony.co.uk - which would indicate these are for other purposes (i.e. does it all).
So it should be correct.
Hope this helps.
Thanks Quinnicus,
That was my hope, but I noticed there were also two extra screws in the tv to align the stand with the back of the TV. I imagine these aren't strictly necessary though.
I'll put up here whether it all works onces the screws arrive in case anyone else has the same query.
