Hi there
Sorry Quinnicus, but, I think there is a way! (at least on my TV!)
ECO mode --> Power Saving --> Picture Off
(I don’t know if there’s a “shortcut” in this TV)
http://pdf.crse.com/manuals/13LW600114/EN/c_eco_backlight.html
"Saving power by picture brightness
Overview
You can reduce power consumption by changing the picture brightness.
Steps
1. Press the HOME button, then select [Settings] using the / buttons.
2. Select [System Settings] using the / buttons, then press the button.
3. Select [Eco] using the / buttons, then press the button.
4. Select [Power Saving] using the / buttons, then press the button.
5. Select the desired option using the / buttons, then press the button.
To return to the last viewed source, press the HOME button twice.
Available Options
[Picture Off]
Maximum power saving. Picture turns off; sound remains on.
[High]
High power saving. Picture darkens.
[Low]
Low power saving. Picture darkens slightly.
[Off]
No power saving.
Tips
If the power is turned off while [Picture Off] is set, [Power Saving] will be set to [Off] when the power is turned on next time. "
Jannis
| Non mi aspetto nulla. Non temo nulla. Sono libero. - I hope for nothing. I fear nothing. I am free. (N.K.) |
Hi there
There is no way to actually turn the display off when listening to a radio station, but you can display a wallpaper (which i think is animated) or a photo slideshow.
See instructions : HERE
Hi there
Overview
Steps
Available Options
[Picture Off]
[High]
[Low]
[Off]
No power saving.
Tips
Jannis
Hey Jan
Yeah, you are right, however I have looked at this before on another thread previously:
http://community.sony.co.uk/t5/Televisions/KDL-42W805A-Radio-screensaver/m-p/1434512#M17398
The thing is, you have to actually goto HOME > System Settings > Eco > Power Settings EVERYTIME you use the radio and/or change stations or do anything. Therefore its a big pain in the you know what
Unless you are listening to a test match in cricket, its not worth it (again my opinion)
However, you are right I probably should have included it as an option (I forgot about it at the time of reply)
