Hi
Is it possible to revert firmware for KDL42W828B?
I installed latest firmware and I have problems with Youtube (grey background instead black).
Thanks
Edin
Unfortunately not, it's an option enlisted in a wish list towards Sony...
But specifically which is the problem with the background? BTW the apps are normally not updated by the fw, but they are updates by the specific option in the menu (I think the English version is "Update internet content")
Hi
Not sure is this coincidence, but after last fw update I notice that for example when I play something from Youtube in 4:3 format, the rest of the screen is in grey (instead black). English is not my native language but I hope that You understand what I mean. Afer FW update I have also problems (from time to time) with startup logo. Strange thing is that gray background and startup logo problem is not present all the time. Sometimes works normally.
Thanks
