Thanks BigBen See you Have The KDL 55 I Would Like To ReStart SetUp From The Beginin But Believe This Can Cause Some Settings To Drop Out. With All The Helpful Info Around This Should Be Straight Forward Like Setting Up Google zeta, I Have Not connected To The internet as Yet. Any Advice Appreciated.
Thanks.
George.
Hi Quinnicus
Thanks For The Info. Might Do The Easy Reset And Not The Factory Reset. Will Let You Know Later.
Regards.
