How do I reset media receiver MBT1-W1?
The Media receiver 6 buttons are not responsive ; they either dont cause any action on the monitor or cause rapid movements through choices without allow picking a particular one. Turning off and on doesnt help.
Remote control is also non responsive. Tried to reset through up arrow and turning off screen, but it wouldnt go back on by itself. New batteries didnt do anything either
Thoughts?
Thanks
Hi there
To reset the MBT-W1 back to factory default settings:
See pages 31 to 33 of the manual : HERE
_________________
Hi there
Om de MBT-W1 resetten op de fabrieksinstellingen:
Zie pagina's 31 tot 33 van de handleiding: HIER
Proost
Hoe kan ik mijn media receiver MBT W 1 resetten? Wanneer de tv wordt aangezet komen er gedurende een aantal min storingen (hakkelend geluid en beeldflitsen)
How can I reset my MBT W1 media receiver? When my TV is switched on, I am experiencing some interference with the sound and picture.
Hi there
_________________
Hi there
Proost
