Looking to put the above on the wall. Purchased the correct Sony Bracket however I've not got the VESA adapters which came with the TV.
Various kits which say they're suitable for the kdl w series but not for wd....... any ideas where I can get the correct ones.
Hi brisso23,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
