Hello, I have a KDL-37EX403 bravia tv. There is no registration code when I go into Activate Enhanced Features (using the Home button on the remote). I need this to create Sony Essentials account. The device is registered. Where it says Registration Code, it says the device is registered but there is no code!
Please can someone help?
Message was edited by: Rosekia
Hi
You can create an account online and then pair the TV that way. This might be a little easier.
https://account.sonyentertainmentnetwork.com/pc/reg/account/create-account!input.action
Hope this helps
Hello,
I've tried that and it still doesn't work. When I try to link my TV to the account, after I have I entered the activation code which I got from Link an Account (via Home on the remote) and entered my bank details, it then says :
when i go to update your essentials account, i can't login as it's not set up. then i try and set up a new account and in the process it asks for my registration code, which without this code i can't seem to set it up! so frustrating! is there anyway I can reset this code somewhere or get a new one?
Please see screenshot below:
thanks
I have the same issue, I am trying to get LOVE film activated on my Bravia TV. When I try to add a device to my sony essentials it says I need to merge my essentails account ....
I'm having the same problem too (December 2013)
Sony, have you all gone home and given up on Customer Service?
I mean this is worse than Ridiculous.
I see that others have had the same issue and you have not even bothered to reply.
Can you please advise urgently on this issue: (same as above)
basically i keep going round in loops as its expecting me to transfer information from a non existant account.
Your Essentials account information has not yet been transferred to Sony Entertainment Network. Please Update your Essentials Account before proceeding.
I *did not* have an Essentials account. So how the ****** can I transfer it. But until I do I cant move on.
Seriously this is something I would expect from a two bit company, but not a major player such as Sony. Very poor.
Advise urgently on how to sort this bug out!
Best to give the helpdesk a call when they are back in the office after the break on 0844 8466 555 as not sure its anythign that can be done remotely. Sounds like they need to make some changes on their side to your account.
Thanks
Hello,
I have KDL-50W950D Sony Bravia TV.
The. Registration code - DXXAZ .
So active my Sony essential account. So able to access amazaon prime video service and other app too.
Thanks and Regards,
Dhanajay Jadhav
Please send me the registration code.
