reading around the forum, I have understoond that it is not possible to record TV programs from my HX820 Bravia TV to the Hard Drive (320 Gb) of PS3, without any other accessory. Is it true?
Thanks for help
Hello nrap412
That si just not possible because the PS3 doesn't have aux in. the onnly way to use the PS3 as a DVR is to buy the "PlayTV" accessory. You will then be able to record TV program on PS3's HDD.
You can also use the HX820 to record on a HDD connected to teh TV by USB 😃
