Hi there
Ok, so you have changed the HDMI cable with no difference - have you tried a different port on the TV? Also ensure that the display output on the Mi Box is set correctly (i.e. 1080p etc)
Unfortunately your picture was not attached to your post.
Also, is the random pink/green screen only when you view the Mi Box?
