Hi Guys,
I am new to this community and very excited to become a valid member. I have to admit I am in a bit if a pickle with my TV though and would like some expert help
My question is when watching Blu Ray movies on my KDL48W585B - I sometimes get this grainy effect especially on darker scenes, I also feel like the colour is dim compared to how the image appeared on the shop floor when I bought the TV. I love my Sony Bravia but feel very frustrated as however much I fiddle with the settings (sometimes for the duration of a whole movie) - due to my lack of knowledge I feel like I cannot enjoy the TV the way it is supposed to be.
I also play PS4 and also feel my settings do not quite work with this either
It feels like the better the technology and the more money you spend - the harder and more complex it becomes to just enjoy your own TV to its maximum capabilties
Any help would be fantastic as I am dying to just enjoy my TV the way its intended
Once you've done above:
Ensure you do this for either your Target Input (current device) or Common (for all devices).
And Scene Select to : General
Settings:
Reality Creation : Auto (see if this helps)
Film Mode : OFF
Advanced Settings:
Auto light limiter : LOW
Live colour : LOW
Detail Enhancer : LOW (or even OFF)
Edge Enhancer : LOW (or even OFF)
Other than that, and the eco settings - I cannot think of any other setting or reason why you would get so much 'noise' on the TV.
Hi there
What you are experiencing is different display settings depending on what you are watching. You would have modified the picture settings in regards to watching TV. However you also need to modify them for other connected devices.
However if you do not require or want different settings on your bluray player compared to the TV. What you need to do is ensure that the correct picture settngs are on the TV, but under the picture options, ensure that the settnigs are for "Target Inputs = Common". Then all you have to do is change the picture settings target input on the bluray player to common, and all the settings will be transferred. I hope this is making sense, as its harder to describe than actually do.
Howhow, to access the TVs picture settings when the Bluray player is on. use the following instructions:
To change TV settings whilst using another device, do the following:
There are also other options in the Sync menu of which you dont have to go through that process (unless you need to that is). Such as "TV Control"
Also, another tip, especially for dim picture, is in the Eco Settings of the system menu, ensure that "Light Sensor" is OFF.
Also have a look at this FAQ:
http://community.sony.co.uk/t5/how-tos-faqs-tvs-home-cinema/faq-best-picture-settings/ba-p/1821711
Hope this helps
Hi Quinnicus,
Thank you for your message and for taking the time to reply to me.
I have already figured out most of what you detailed in your message. I can control the remote on different devices and adjust the picture, ECO settings are off etc.
The trouble I am having is this -
I have configured everything to get a great picture on both TV and on Blu Ray which is great, however when a dark scene comes on (either on TV or on a blu ray) the image appears grainy, like the shadow of a character on the film is made up of tiny dots or a dark room has this sort of speckled effect which then leads me to feel I have actually not set it up right as I am sure a blu ray movie displaying on a Sony Bravia should not be grainy so then I fiddle some more and then the colour turns dull - it's never ending
Something that crossed my mind is perhaps the sharpness has something to do with this but even then after fiddling around with the settings more, nothing changes and after adjusting the colour and what not - I can either have dull/average colour or crank it up so that it looks like everyone has just taken a strong hit of LSD
I really appreciate your help on this
Hi there
I understand your problem now
Hmm, how to help you is another matter - as you shouldnt be getting a grainy picture on black. Ok, this is going to be a pain in the butt (for you), but can you list all your picture settings that you use as well as the advanced picture settings. Also, are you able to take a photo of the problem (grainyness) and post it back here?
The thing is, im struggling to figure out a setting that would either do this, or correct it - so looking for a place to start (if you get where Im coming from?)
Brilliant! I am at work at the moment but will get something over to you later on.
Thanks so much
Evening!
Here are the pictures of my set up and a picture of the graininess on a dark image. Also I have realised I am not sure about the eco light setting you mentioned, could you confirm how i turn this off?
Also settings are as follows
Backlight 6
Contrast Max
Brightness 50
Colur 60
Hue 0
Colour temp Neutral
Noise, MPEG, DOT NOISE reduction all are Auto
Smooth Gradiation Low
Film mode auto
Advanced settings
Black corrector Medium
Adv Contrast enhancer Medium
Gamma 0
Auto light limiter Medium
Clear white Off
Live colour Medium
White balance - Have not touched
Detail Enhancer Medium
Edge Enhancer Medium
Skin Naturliser Off
Display Speed Preference - Greyed out but says OFF
LED MOTION OFF
Let me know what you think!
Thanks
Hi there
Thanks for the picture. Settings look OK. Turn of ALL eco settings. Its located : HOME > System Settings > Eco
Also, just to get things as default (and not auto) - Set Scene Mode to 'Standard'
HOME > Display > Picture > Picture Mode
I'll get back to you with other suggestions (if I can) a bit later.
Settings:
Film Mode : OFF
Advanced Settings:
Live colour : LOW
