Hi there
The following thread should explain things:
http://community.sony.co.uk/t5/Televisions/Enlarge-subtitles-on-bravia-kdlex650/td-p/644592
HI there
Sorry about that, I took it as subtitles. Unfortunately the answer is basically the same though. It is fixed and cannot be changed. However I think this time it is controlled by Sony - but is unlikely to change it.
Bigger TV is what you require unfortunately.
