I am trying to use HDMI for connection between KDL-50W805b and Yamaha TSR-700 AV-amplifier.
I cannot use ARC since the amplifier constantly losses connection with TV.
An optical cable connection is a bit better, but not stable (HMDI control is enabled both TV and amplifier). Symptoms, if I listen to music from NAS or blue-ray disk and open the TV, the amplifier switches source automatically from NAS/Blue ray to TV and the system sound vanishes. It looks like the TV lost connection to amplifier because I can see the sound output is switched to TV from a setup menu. If I switch it back to AV-amplifier the sound comes both TV and amplifier. The only way how I can fix it, is to close either TV or amplifier and open it once again.
The amplifier retailer claims this is the TV problem, but I am not convinced. Has anyone else have the same problem or idea what might be root cause to the problem?
Hi nikorho, I'm sorry to hear that you're facing this issue.
Try the below to resolve the issue:
-Make sure that you're using the connections on the startup guide here: https://www.sony.com/electronics/support/res/manuals/4489/44895091M.pdf
-Unplug the TV from the mains for two minutes, while removing all the external devices.
-Make sure to update your TV: https://www.sony.co.uk/electronics/support/lcd-tvs-kdlxxw8xxb-series/kdl-50w805b/downloads/00017151
-Follow the steps here: https://helpguide.sony.net/gbmig/C5361001/v1/eng/index_998_595.html
-Reset the TV to the factory settings: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kdl-32ex301/articles/00170...
Let me know what happens, please.
