hi,
I have a problem, after the update 8535, no longer works wi-fi, applications, usb, etc.
The TV tuner works, but the smart side fell ...
Now does not see the usb port, so I can make it the 8535 update
what can I do...
Hi @valiball and welcome to the Community
Which model TV do you have?
It sounds like you will have to do a factory reset on your TV.
