Seems I am unable to login to the Picasa app on my recently purchased KDL-55W829. Returns the error that my login credentials are not correct but this is not true. Have used these credentials on all other devices and login just fine.
I get a message to my google account suggesting suspicious activity (attempted login) in each login attempt. Have also tried the 2 step verification process...makes no difference.
I suspect Sony's server is blocked by Google or visa verse?
Please investigate or advise!
Hi there
More information is in the following thread:
http://community.sony.co.uk/t5/televisions/picasa/m-p/1590685
I was actually hoping that this issue was resolved - but aparently it is not. Ill chase this up
Hi there
I have just tested the Picasa application on my TV and all now appears to work. Can you please test it as well and confirm?
Thank you
Hello Quinnicus
Still no luck i'm afraid...got the same notification from Google showing a "suspicious login attempt".
Many thanks for your reply none the less
Kind regards
Raj
Thank you for the update and Ill feed it back to Sony.
Dont even know why its now working for me either !!
Hi there
The information I have got is that its a Google issue not Sony. So... Can you please try the following and see if it works.
Fingers Crossed.
Hi Quinnicus
Struggling to find the browser! Can you please advise?
Kind regards
Hey there
Its under "All Apps" - This thread should explain where it is:
http://community.sony.co.uk/t5/televisions/internet-connectivity/td-p/1648559
And
http://community.sony.co.uk/t5/televisions/internet-browser-access-on-kld-32w706b/m-p/1662121
However its a bit of a long shot to be honest.
Got it!
Still no luck unfortunately...same issue!
Many thanks
Thats a shame. Ok, below is exactly what I have been told - See if you can make head or tails on it, as I cannot. The links in the email I get are nothing to do with confirming its me - do you? Im not sure If im being thick here, so....
It's a Google issue. When you change a device or use a new device with an existing Google account Google warns you as they think your account might be hacked. Therefore you need to confirm that you're the real user by clicking on the link in the e-mail.
Why does it suddenly work for me - Pass (maybe ive tried so many times, Google gives up and thinks im me!)
