I bough this TV last June and have experienced no problems until now.
The iplayer is accessible but it is going directly to a display failure page. My internet is fine- lovefilm has no issues, my software is up to date and I have redone the digital set-up and refreshed the internet connection.
iplayer plays fine on my lap top - is it anything to do with DRM? Any ideas?
Many Thanks
DT
Sounds temporary, couple of things to try..
Might be glitch at BBC side, but pretty sure the above will sort it.
Hi Batfinkk
Thank you for responding.
I have tried your suggestion but the problem remains. Must be a BBC thing, it does state that "in certain network situations, it may not be displayed even under correct setup.", which is so helpful.
I will go to iplayer site and see if they have more info.
Thanks
DT
I have looked on iplayer site and there are some technical issues involving various platforms including BT vision, which I don't have but BT is my IP.
http://iplayerhelp.external.bbc.co.uk/help/announcements/iplayer_unavail_010213
