profile.country.en_GB.title
robeaston33
Visitor
NX713 or HX803
I am looking to buy one of these TVs from Currys. They say that there is a warrenty in the box. Is this 5 years???
Also, I think by the forums the HX has a better picture, but clearly the NX is a better looking TV.
Also, the sound bar or silver stand for the NX at 6 degrees angle, does it improve the sound quality?
Really appreciate your help.
Thanks
Rob
1 REPLY 1
Catmambo
Contributor
A lot of it will come down to personal preference and pricing to be honest. Personally I would probably opt for the HX as I hardwire my devices to the network and don't wall hang so a super thin device isn't of benefit to be honest.
The stand probably won't improve the sound massively, but I think improves the look of the device as a whole if you aren't wall mounting. I'd definitely ( as I'm sure you have already) look at them both in person regardless of wherever you buy them from.
Thanks
