I want to use Freesat on my TV and my dish is set up with quality components but I get no signal showing on the satelite setup page. My inline satelite finder, that also monitors the voltage sent to the LNB does not show any signal. I have tested the cable up to the LNB and all connections are good and are not shorted. Anyone help.
Hi there
I would advise you contact a Aerial/satellite technician if this is still causing you problems.
Cheers.
