Hi, did try this a couple of days ago with result, but just tried it again and it does work, so problem solved.
Thanks.
I get Iplayer subtitles on my Android KDL-43W756C, but do not get them on my new KD-49XF7073. Please explain how to get Iplayer subtitles on the KD-49XF7073. Thanks
@Sayno. wrote:I get Iplayer subtitles on my Android KDL-43W756C, but do not get them on my new KD-49XF7073. Please explain how to get Iplayer subtitles on the KD-49XF7073. Thanks
Hi @Sayno. Assuming that you mean BBC iPlayer then simply press Select while a programme is playing and switch on Subtitles [S] if they are available. To learn how to use BBC iPlayer go to Settings -> Settings & Help -> Help -> Accessibility etc.
