I may have stumbled across the solution to this guys! Each time you turn on the TV, simply tune into Vintage TV (Channel 82 in my area) which shows initially as "No Event Information". Give it a second or two and it then updates not only this channel with the event info, but also ALL the others that were missing!! It's as if this is the key channel to unlocking the data. It works for me and as such a simple solution I thought I'd offer it up to you to try! Good luck!
Hi there,
Thanks for sharing.
Sean Mc
