I am looking for a new 32 inch TV for my kitchen. I already have a superb 55 inch Sony Bravia and so Sony will be my natural choice. At Curry’s yesterday, although more expensive than all the others, the KDL-32WD752 picture quality was also noticeably better than all the others. However, a Sony representative was present at the store who hinted that this model was introduced three years ago and a new model may be due for release.
Does anyone know when?
Having checked out Sony’s website today, I was surprised not to find the KDL-32WD752. Has it already been discontinued? On other vendors’ sites I saw the KDL-32WD754 and KDL-32WD756. Both appear to have a black bezel (my preference), so assuming I end up with the KDL-WD75 series, what’s the difference between these two variants?
We are all customers like yourself, so unless somebody has seen a press leak on new models it is very doubtful that anybody will know when the new models will be available. You should note that the Sony numbering system shows the model year. WD = 2016, WE = 2017, WF = 2018 etc. Looking at the Sony site the last 32” model was 2017.
As far as the 2016 models KDL-32WD75x are concerned the comparison below shows they are very similar. (Correction, the 6 doesn’t appear to have satellite tuners).
https://www.displayspecifications.com/en/comparison/6c513f72d
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kdl-32wd752/specifications
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kdl-32wd754/specifications
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kdl-32wd756/specifications
Hello SonyUser30Yrs
Many thanks for your very prompt reply and the edit regarding the apparent error in the "displayspecifications" website comparison that, thanks to you I have now discovered.
I'm still surprised that the KDL-32WD75x can only be found under Sony's support tab and also that only the KDL-32WE613 and KDL-32RE403 are listed as being current products - especially when, having examined the specifications, only the KDL-32WD75x series have a full HD display.
So, where I am now is I still didn't find the difference is between the 32WE754 and 32WE756 and am temporarily putting up with having to squint at the 24 inch Panasonic currently in my kitchen.
