I have just purchased a new Sony KDL-46W905A today. I cannot get the Netflix app to connect. I click on app and it gives me error NW4-8. I have been in contact with Netflix and they can't even sort it. Internet is fine - just can't connect to Netflix servers. Has anyone any ideas it's driving me nuts
Just had a twitter notif from WhatHiFi
@j_a_griffiths @chris18117 We have asked @SonyUK for an update and will let you know.
Maybe they will get somewhere
Hi all
I just wondered if any of you have tried using Chromecast as a temporary solution to be able to watch Netflix while you're waiting for Netflix / Sony to give you some more info?
Its not ideal but for £30 it may save you being fed up / returning otherwise fantastic Television sets.
Have a look Here
I tried use chromecast 2-3 weeks ago. Looks like chromecast is using sony netflix app. Same error. Maybe if we uninstall netflix from tv and then.... I sold chromecast after that as I couldn't use it.
@bw444976 I can certainly understand that. I only offered a potential solution for those in desperate need of Netflix.
It could be argued that if people cannot live without Netflix then what is another £30 compared to the probable thousands they have spent. (Especially if no solution is coming soon.) I certainly wouldn't dare to argue that here though
Also my advice to everyone is if you're not happy with state of the art Television sets just because they can't play Netflix then why not just take them back? (Or I'll swap you my old set that does work with Chromecast and I can have a nice new shiny one.) I'm joking of course but it doesn't look like there will be a solution coming any time soon. (This thread started 2 months ago)
@Filding Thanks for the feedback. I wonder if anyone else has tried Chromecast and found problems with it?
It would be great if they could let us know here so at least some people may have a temporary solution.
Hi All,
I have tried chromecast for the temp fix and it works without a hitch. You have to follow install instructions to the letter (or at least I did) and as I have a BT hub 3 I had to go into the settings of my home router and change the channel (to 11 or higher it says) and all works with netflix like a charm and use my iphone/ipad to sync/control it like a remote control.
Still haven't figured out the morroring from devices yet but one thing at a time. Otherwise apart from agreeing with everyone about they def need to get it right... this has taken some of the sting out so I can enjoy netflix until sony can sort it. Otherwise v happy with tv, if slightly miffed with time spent on resoloving the netflix issue!
